Need help. Hydraulic fluid spraying everywhere
Old Jun 26, 2011 | 01:52 PM
KG89's Avatar
Default Need help. Hydraulic fluid spraying everywhere
Audi A6 2000
Whenever I start my engine my hydraulic fluid is spraying all over the place. It’s coming from the hole in the cap. Any ideas why is this happening ?
Old Jun 26, 2011 | 05:40 PM
bob martin's Avatar
By "hydraulic", do you mean power steering fluid?
Old Jun 26, 2011 | 08:16 PM
KG89's Avatar
Yes I believe thats the power steering fluid
Old Jun 27, 2011 | 07:33 PM
bob martin's Avatar
If it is only coming from the cap, chances are the cap isn't on correctly or that the cap is defective somehow. If you have no other signs of failure, that's about all that can be wrong. Of course, your description isn't the last word in detail, so YRMV.
Bob
Old Jun 27, 2011 | 08:41 PM
chefro's Avatar
I agree with Bob.
Reservoirs have a cap for a reason: to keep the fluid in, especially when under pressure.
The Power steering system is pretty much a "closed loop" one. There's no "overflow" unlike let's say the cooling system.
There's no venting "hole" in the cap, so you either have a defective cap, or isn't on correctly as Bob already mentioned.
Old Jun 27, 2011 | 11:58 PM
KG89's Avatar
Bob
There is defiantly a lot of noise coming out when I turn my steering wheel. Fluid turned into foam.
I also started getting some clicking noise when I’m trying to make a right turn,I think its from the axle would that be the cause of this problem ?
Old Jun 28, 2011 | 09:52 PM
New Audi Man's Avatar
I am having the same problem. There is a breather hole in the cap. I am getting foaming and the pump that was suppose to be new is whinning, when I turn off the car I can see bubbles coming back into the resvouir. I cant find the leak but the power steering fluid is down under by the spark plugs. Have you looked to see if you have any fluid there?
Pbcrazy
Sep 10, 2012 10:56 AM
AudimaniaA4
Feb 22, 2009 10:20 AM
straitgame22
Aug 23, 2006 01:54 AM
thrax982
Mar 31, 2005 10:15 PM
