Need Help, Please Translate Whats Wrong For Me
Old Jan 1, 2009 | 06:00 PM
adidasallstarguy's Avatar
Angry Need Help, Please Translate Whats Wrong For Me
VAG-COM Version: Release 311.2-N
Chassis Type: 4A - Audi 100/A6 C4
Scan: 01,02,03,08,15,17,25
Address 01 -------------------------------------------------------
Controller: 8D0 906 266 A
Component: 2,8l V6/2V MPI OBD2 D03
Coding: 01242
Shop #: WSC 23247
1 Fault Found:
17816 - EGR Temp Sensor (G98): Signal too Large
P1408 - 92-00 - Unknown Error Elaboration
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 4A0 927 156 AL
Component: AG4 01F 2.8l2V USA D25
No fault code found.
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 J
Component: ABS/EDS BOSCH 5 7679
Coding: 0265109024
Shop #: BB 37679
Address 08 -------------------------------------------------------
Controller: 4A0 820 043 K
Component: Klima-Vollautomat D05
Coding: 00062
Shop #: WSC 02325
1 Fault Found:
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4A1 919 035 CJ
Component: C4-KOMBIINSTRUMENT D2|
Coding: 00262
Shop #: WSC 40232
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
End -------------------------------------------------------
Old Jan 1, 2009 | 08:30 PM
nm3210's Avatar
Well this isn't very useful without knowing what is actually going on with your car....so....what's wrong with your actual car?
Old Jan 1, 2009 | 08:47 PM
Default Symptoms
Well my main problem with my car,that I can't seem to fix is that that ABS is going off or at least making the noise most of the times I stop. Another issue is that my temperate gauge doesn't seem to be working, but by the codes i figure I need a temp sensor. Every thing seems to be going wrong. Here is all I have replaced in the last 2 months. Radiator fan motor,struts, brake pads, rotors, calipers, front Axles/cv joint. I was told the axle would probably fix my brake problem, they said they tested the sensors and they was good but he thought somehow the axle was causing the brakes to possibly do this. I hope someone can please help me, I've been without my ride for basically 2 months. I love this car but I've been putting way too much money in it.
Old Jan 1, 2009 | 11:13 PM
WolfsA62.8Q's Avatar
You have basically 2 error codes :
Address 1:
" 17816 - EGR Temp Sensor (G98): Signal too Large
P1408 - 92-00 - Unknown Error Elaboration "
> EGR > Exhaust Gas Recirculation temp sensor. If you have a Bentley book, it will show you where the sensor (G98) is locates.. probably near top, back of engine.
And Address 8:
Fresh air blower.. could be the motor, or short in the wire to the blower motor.
These won't affect your temp gauge, if you mean the coolant temp. You may have to replace the ABS module, they are known to fail, but test the sensors first, they are a lot cheaper to replace.
organic355
Jun 4, 2011 10:47 AM
missa4
May 5, 2008 11:31 AM
arb
May 18, 2007 07:23 PM
dpunisher95
Feb 8, 2007 05:02 AM
shinnny
Feb 23, 2006 05:18 AM
