need SERIOUS help~
Old Jul 30, 2006 | 01:00 AM
abkyl's Avatar
Default need SERIOUS help~
2000 a6 2.7t, my abs light stays on and my e-brake light keeps flashing.. anyone heard of this before?? probably gonna take it to audi on wed to get it check it out.. damn.. here goes more money...it better be worth it~
Old Jul 30, 2006 | 01:20 AM
DaShockMan's Avatar
Default RE: need SERIOUS help~
More than likely its your abs pump module. Search on ebay for the place that rebuilds them. It takes about an hour to remove the module, and you can drive the car without it. They charge 200$ to redo the module and that includes the shipping label they send you to use to send it in. Or they dealer will charge 2g's for a new one.
Old Jul 30, 2006 | 02:48 AM
audiSean's Avatar
www.modulemaster.com
Give them a shout. The dealer will absolutely leave you feeling like you've been given an STD on this one.
Old Jul 30, 2006 | 04:12 AM
abkyl's Avatar
wat do i search on ebay??
Old Jul 30, 2006 | 07:40 PM
mpw2.7T's Avatar
Default Do some searching on AudiWorld
ModuleMaster
It definitely sounds like your ABS control module, but there are a couple other things you should check first.
Old Jul 30, 2006 | 10:41 PM
DaShockMan's Avatar
Default RE: Do some searching on AudiWorld
search for "audi a6 abs rebuild" There is a auction for a rebuild. Its 199$. Cheaper than module master and does the same thing.
Old Jul 31, 2006 | 05:56 AM
luvin_the_rings's Avatar
i kno i had the same thing on my a4, it was just a frayed abs wire on the front right steering knuckle
Old Jul 31, 2006 | 08:00 AM
techbod's Avatar
check all the break light bulbs are working if one is blown then that's the result
Old Aug 9, 2006 | 01:05 PM
CRAZYHAWK's Avatar
Have it VAGed. It could be a wheel sensor.
