Need some tech help on error codes...
Old Jul 9, 2007 | 06:35 PM
mustang196718's Avatar
Default Need some tech help on error codes...
okay, my car threw a cel and i thought it was just a dirty maf but i tried cleaning it and it didn't change,but the car still runs fine. my abs and traction control lights are also on, but i have no idea why, but here are the codes i'm getting so hopefully some techy out there can helpme:
Address 10 (Engine): 1 Fault Found:
P0102 - Mass Air Flow Sensor (G70): Signal too low
AND...(from the ABS module):
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
someone please help me, i don't know what to do to fix these. i tried clearing them and they come right back immediately.
thanks,
mike
Old Jul 9, 2007 | 07:06 PM
auditech79's Avatar
Default RE: Need some tech help on error codes...
Thats an electrical fault from the MAF sensor, either the signal wire from the MAF to the ecm has resistance in the wire, or the MAF sensor itself is bad (more likely)
The fault in the ABS is caused by the engine fault, so fixing the engine problem then clearing the fault in the brake electronics will fix that.
Try swapping out the MAF sensor with a friend if you know one.
Old Jul 9, 2007 | 08:16 PM
ORIGINAL: auditech79
crap, i wish i did. fort wayne, indiana seems to be a lonely place for audi owners though, because they seem to be few and far between, and i don't know anyone else unfortunately.
Old Jul 9, 2007 | 08:24 PM
auditech79's Avatar
Ugh, that sucks, you probably just need to replace it, I replace quite a few of them on a regular basis.
Old Apr 30, 2008 | 06:08 AM
katcoota's Avatar
Mustang,I have the same two error codes:
P1857 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
and another one:
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-10 - - - Intermittent
Did replacing the MAF sensor fix your problem?
I have the 4.2 engine with 117k miles on it.
Thanks...
Old Apr 30, 2008 | 09:37 AM
katcoota--it ended up being a loose wire in the MAF wiring harness. i just reconnected the wire and all was well again, so i never ended up needing to replace the actual MAF.
Old Apr 30, 2008 | 09:58 AM
katcoota's Avatar
Aah, sometimes it is as simple as that . Will havea look later this weekend. Will probably clean it too as I've never done that.
Thanks for the quick response.
Old Apr 30, 2008 | 10:50 AM
spyder's Avatar
I am using the unreigstered version of Vag-Com so it doesn't give me the description for some of the codes. I was just wondering someone might have the code manual or maybe you have experienced them before.
4 Faults Found:
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High ( does this mean i need to changed the O2 sensor? If yes, where can I find a good one?)
P1131 - 35-10 - - - Intermittent
16805 - Shareware Version. To Decode all DTCs
P0421 - 35-10 - Please Register/Activate - Intermittent
17521 - Shareware Version. To Decode all DTCs
P1113 - 35-10 - Please Register/Activate - Intermittent
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-00 - -
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201) ( is this for an individual wheel? )
27-10 - Implausible Signal - Intermittent
ParadoxZero
Feb 27, 2014 06:41 PM
Macfly
Jul 20, 2012 11:06 AM
keko2004
Sep 14, 2007 11:05 AM
Johns2000A4Q
Dec 7, 2006 07:50 PM
hoonee46
Mar 6, 2006 05:43 PM
