new 2002 A6 2.7t owner questions
Old Oct 3, 2008 | 07:17 AM
jholty's Avatar
Default new 2002 A6 2.7t owner questions
I have read the tips and suggestions post in this forum and have a couple of more questions, please forgive me for my ignorance. I plan on having my 89K mile A6 serviced for the timing belt, fuel filter, trans fluid & filter changed, spark plugs/wires, and a leaking rear diff. serviced. Is there anything else that i might need to have looked at that i'm not aware of? The car has new brakes and tires already and the alignment seems fine. Before i purchased the car yesterday i was under the care while it was on the lift for almost an hour and i could not see any problems, other than a leaking rear diff. All the bushings looked good to me.
Lastly, is there a special make/model spark plug that this car requires?
Thank you for any input you can give, it is greatly appreciated.
Old Oct 3, 2008 | 03:36 PM
Stone825's Avatar
CV Boot, tie rod ends, control arm bushings, control arms and how much did you pay for the car?
BTW it is a Bi-Turbo
Old Oct 6, 2008 | 08:53 AM
bob martin's Avatar
Parralell twin turbo is the correct nomenclature. Bi-turbo is the marketing nomenclature.
Old Oct 6, 2008 | 07:13 PM
ppgoal's Avatar
Cabin air filter. You may want to purchase a K&N online and replace the air filter -- but be careful to ensure the K&N is well-drained so you don't get oil on your MAF and ruin it.
Make sure the TB job includes the tensioners, thermostat, and a water pump with metal impellors.
Vuilhond
Mar 11, 2010 08:18 AM
john@astigracing.com
Dec 17, 2009 11:44 AM
squib_2000
Jul 28, 2007 03:36 AM
MPLSChase
May 5, 2007 07:33 AM
