New to Audi, need advice/help
Old Sep 9, 2009 | 04:21 PM
NH_USA's Avatar
$70 to pull codes may be reasonable at an Audi dealer but you'd be better off to get an Ebay cable and the Ross Tech software so you can read them (and reset them) yourself. All it takes is a $20 and a lap top or a computer with a long USB cord.
Old Sep 15, 2009 | 07:09 PM
CardinalsWin's Avatar
Alright, well I figured out whats wrong with the brakes. At some point, someone put new pads on the car, but did not turn the rotors. The pads didn't seat well and are wearing unevenly. I believe I just need to replace the pads (worn unevenly) turn the rotors, and bleed/flush the fluid. My Bentley manual says I need a special tool for bleeding these brakes (ABS), tell me that's not true!!
Old Sep 15, 2009 | 09:39 PM
Midniteoyl's Avatar
Check those rotors first. Every rotor on an Audi is already too thin and usually cannot be turned.
Old Sep 16, 2009 | 10:54 AM
NH_USA's Avatar
I never had a problem with pads not seating properly when using new or old rotors.. Uneven wear usually means you have a hung caliper.
Old Sep 16, 2009 | 11:28 AM
hxgaser's Avatar
You need a pressure bleeder of some sort. I never, ever had luck with bleeding ABS brakes with old style, pump the pedal way. The best choice is a full size pressure bleeder like Motive powerbleeder. But it is expensive. I have a Mityvac handpump style bleeder and it works fine.
BTW, how are the pads wearing unevenly?
mezonesxbox
B7 Models
Mar 27, 2014 03:48 PM
Loomis
Jan 8, 2010 11:36 AM
SpYdR
Nov 1, 2007 09:10 PM
aykt1
Feb 19, 2006 06:01 AM
