New guy question, 1995 A6 running issue
Old Sep 3, 2009 | 02:25 PM
NH_USA's Avatar
Yes -- clear the codes and see what comes back --
The oil pressure light would be my BIG concern because it indicates a bigger problem than a few CEL codes.
Old Sep 4, 2009 | 02:49 PM
renaissance_warrior's Avatar
Re; oil light. As I had mentioned, the OP light goes OFF when you are at lower speeds and rpms. LIke it is wired backwards or shorted.
Old Sep 4, 2009 | 08:09 PM
m000035's Avatar
Originally Posted by renaissance_warrior
... the OP light goes OFF when you are at lower speeds and rpms. ...
Sounds to me like oil starvation. The oil pump pumps the oil out of the pan faster than the oil can return. I've heard about in on some Olds big blocks, but not Audi's. How full is your oil? Do you know how accurate your dip stick is?
Old Sep 4, 2009 | 10:33 PM
a6hcw's Avatar
Carbon from cheap oil may plug up the oil intake before the oil pump. Also, the oil filter and the pressure relief valve may be plugged up. Which 2.8L 12 valve engine do you have?
bryn123
Feb 25, 2013 11:09 AM
romanI
Jan 12, 2011 09:32 AM
soautomatic
Jan 1, 2011 03:15 PM
bwsmd
Apr 27, 2008 10:57 PM
kkstickboy
Dec 11, 2007 09:15 PM
