new member and question
Old Sep 9, 2006 | 04:09 AM
jchussey's Avatar
Default RE: new member and question
A leaky valve cover gasket will not introduce moisture into the cylinder. WTF?? Besides, these last a long time on the 2.8 A6 from my experience.
Moisture in the cylinder would be caused by a leaking head gasket, in which case coolant would be leaking into the cylinder. Was the car severly overheated? I even doubt this is it as I overheated a 2.8 and it is fine to this day, 40,000 miles later. I recommend considering the plugs and wires if they are older than 50,000 miles. Don't let the stealer, I mean dealer, rob you of $375!!! Moisture in the cylinder is extremely difficult to diagnose unless it is severe. No electronic tester will tell you this-- it will only tell you there is a misfire in a certain cylinder. Plugs and wires shoud cost you no more than $ 60 and are and easy installation. If the problem still exists, then I'd look at # 2 module-- also an easy, fairly inexpensive fix. Start with the cheap stuff first and rule out the ridiculous.
And pleeaaaase-- don't spray you plug wires with water-- that is a ridiculous suggestion.
Old Sep 11, 2006 | 08:34 PM
audinewb's Avatar
i dont think spraying plug wires with water was ever a suggestion. but where the hell can i get plugs and wires for $60 ive been searching for about a week now and the cheapest plug set i found was $160 and about $10 a plug.
Old Sep 12, 2006 | 07:29 PM
audinewb's Avatar
i take that back but i dont think id do that anyways.
bbowers825
Nov 5, 2013 09:41 PM
drose1068
B7 Models
Sep 11, 2013 09:15 AM
Crispin
Jan 29, 2012 05:30 AM
boandrock
Dec 20, 2008 06:22 AM
RDHyde73
Oct 2, 2006 03:49 PM
