No Lights, Blinkers, A/c & Wipers
Old Jun 10, 2007 | 03:33 AM
A6QMelange's Avatar
Default No Lights, Blinkers, A/c & Wipers
98 a6Q No Lights, Blinkers, A/c & Wipers Does anyone know if this is a common problem? I've read previous posts that lean more towards the ignition switch. Before I replace it, Does anyone know any tests I can do to make sure it is.
Thanks
Old Jun 10, 2007 | 09:46 AM
mpw2.7T's Avatar
Default RE: No Lights, Blinkers, A/c & Wipers
Scroll down about 10 posts...
Old Jun 28, 2007 | 02:57 AM
mustang196718's Avatar
i'd check the fuses before you go replacing ignition parts. a 15 cent fuse definitely beats paying for a several hundred dollar ignition switch.
Old Jun 28, 2007 | 07:29 PM
mpw2.7T's Avatar
Definitely check the fuses, but if it is the switch, it's less than $30.
http://www.autohausaz.com/search/pro...ition%20Switch
Old Jun 29, 2007 | 01:48 PM
barryoy32's Avatar
I also have a 98Q that has the same problem. After starting the car, I turn the key slightly back toward me. That's it.
Old Jun 29, 2007 | 04:37 PM
mpw2.7T's Avatar
barryoy32 - You might want to change that switch before you find yourself stranded somewhere.
jnb
Jun 9, 2009 05:45 PM
dendrizzi
Jun 8, 2008 04:33 PM
jstefankowski
Jun 6, 2007 05:12 PM
jfrish
Dec 6, 2006 04:12 PM
