no power, need help ASAP
Old Jul 17, 2007 | 12:41 AM
  #31
millenia's Avatar
Default RE: no power, need help ASAP
Aight thanks, so its probably a leak or the TB thing dirty?
Old Jul 17, 2007 | 12:51 AM
  #32
auditech79's Avatar
Yeah but this will clean everything in the intake system so it takes care of a lot. If that doesn't help then start looking for a leak.
Old Jul 17, 2007 | 12:55 AM
  #33
millenia's Avatar
is that chemtool crap expensive, so i ll spray some propane around the engine, so i start the car up and if my rpm's go up automatically, that means there's a leak, so than i just gotta find where it is, but to me it sounds like the intake thing is dirty, cuz the car sounds like its choking
Old Jul 17, 2007 | 01:01 AM
  #34
auditech79's Avatar
Yeah thats why i told you to do it. You can use any carb cleaner that usually costs around $5.
But an vaccum leak will make it seem like the engine is "choking" because it doesn't recognize where the air is coming into the engine and it adds fuel to compensate.
Old Jul 17, 2007 | 01:07 AM
  #35
millenia's Avatar
so finding that valve shouldnt be a pain in the ***, so just trace that fat plastic hose that goes to the engine take that off and there should be the valve
Old Jul 17, 2007 | 01:12 AM
  #36
auditech79's Avatar
Thats about it mate, good luck. Cheers!
Old Jul 17, 2007 | 01:19 AM
  #37
millenia's Avatar
so spraying propane around the engine is not dangeros it wont go on fire or anything, so how much should i spray?
Old Jul 17, 2007 | 01:25 AM
  #38
auditech79's Avatar
No it can be quite dangerous, don't put it too close to the exhaust manifolds, or have someone stupid smoking or something dumb like that.
Old Jul 17, 2007 | 01:32 AM
  #39
millenia's Avatar
so just spray a little of it and not to close to the engine?
Old Jul 17, 2007 | 01:37 AM
  #40
auditech79's Avatar
Just around the areas where you see vaccum lines, on top of the engine, and to the sides, just don't spray too much on the rear corners of the engine where its really hot.
