Noise after shock replacement
I have a 2000 2.7 and I just got the front and rear shock changed to Bilstien heavy duty. Now the car rides rough and makes a lot of squeaks and rattling noise in the back. Will these shocks loosen up or do I have to replace them? Thanks.
thanks J, that's kinda what I thought. I paid a laid off audi mechanic $550 to do my timing belt, water pump, cam seals, thermostat, and shocks all around. I guess I can't complain too much. I just gotta go back over it and check it out.
I solved that issue by also replacing the stock springs with an Eibach Pro-Kit (couldn't resist lowering the car and improving the ride...
)and making sure the springs are in the correct position. Ah the things we learn by making mistakes!!!
Now I still have the front to do... and make more mistakes in the process.
Can you ask your mechanic to come back and fix the mistake?
You should be able to get under the car and check the direction of the springs; that is the tell-tale.
on a side not, during the disassembly of my shocks to install a set of Eiback coils I also discovered that one of my new Bilsteins was leaking oil. I call the vendor that sold me the shocks and they are sending me a new replacement. I love dealing with FCP Groton!!! Great customer service, and they also sent me a 10% discount card and free shipping for my next purchase. What to buy next???
Oh the dilemma!
Oh the dilemma!
Hey Zippy, I took the wheels off to look at the springs and I could see that they were about an inch off in the rotation. The end of the spring is an inch from touching the bumper stop on the mounting plate. Do you think that's the problem?
