Noise after shock replacement
Old Apr 19, 2010 | 12:09 PM
hxgaser's Avatar
Yes it sure is.
Old Apr 24, 2010 | 06:34 PM
zippy_gg's Avatar
Originally Posted by Cmoney
Hey Zippy, I took the wheels off to look at the springs and I could see that they were about an inch off in the rotation. The end of the spring is an inch from touching the bumper stop on the mounting plate. Do you think that's the problem?
Sorry, I have not been on the forum in a few... but yes, that is your problem.
Since my car came with Bilstein when I bought it I don't have a point of reference with stock shocks. The Bilstein kit lower coil support does not come with a notch or anything to indicate where the bottom of the spring should be oriented. The Bentley manual was pretty useless in that regard too; I got the best info here on the forum....
Old Apr 27, 2010 | 08:36 AM
steckrca's Avatar
Damn I have never heard that about the spring alignment. I've been trying to track down a noise in my front end after doing my control arms, shocks, springs, and sway bars. Everything is tight, but I have this low pitched "ping" sound that sort of sounds like if you hit one of your springs with a rubber mallet that shows up from time to time, especially if you're on a gravel road.
What is the reasoning behind the alignment of the springs? Obviously there's some mechanical logic, but I don't see it. Can someone explain?
mightyb28
Jul 3, 2012 05:30 PM
Julio Quevedo
May 21, 2012 08:24 AM
escyr
Apr 25, 2009 09:33 AM
