Noise when turning steering wheel left or right
1998 Audi A6 2.6.
I'm getting a weird noise while starting the engine, also while turning steering wheel left or right. This is my first car & have no knowledge about the car. Please help me with your suggestions.
We need a better description of the noise, the conditions you hear in under and the length of time you hear it. The start up noise could be normal. You should should hear some lifter clatter until the oil pressure comes up and tightens the tensioner, about 1-2 seconds, and you should hear the secondary air pump feed additional air to the cats to clean up the start up exhaust fumes for about a minute.
For the steering wheel, check the fluid level and be sure to add only Audi specific power steering fluid (or straight mineral oil from the drug store).
Bob
Bob
For the turning aspect of your problems, check your dampening rod. Try just pushing on the side you hear the noise from when it is off and not moving. If you hear the noise it is most likely that your dampener need replacement or lubrication. I have heard noises too, so just spraying some Silicone lubricant on the whole shock itself form under the wheel well.
Can anyone report this nonsense spammer?
unless audirorums supports them??
Thanks-
Thanks-
Before you go to the bridal wedding dress salon for the first time, browse through weddings magazines to get a sense of what you like; it's helpful to bring pictures of wedding dresses that appeal to you. Also, be open to trying a variety of plus size wedding dresses. What may seem unlikely on the rack of the wedding gowns may be stunning on you.
Nevalite
Aug 13, 2012 03:04 PM
Stoned Gecko
Dec 29, 2006 08:33 PM
