not sure if anyone asked...
Old Oct 14, 2007 | 12:47 PM
tahoehtp's Avatar
Default not sure if anyone asked...
well I just wanted to know if anyone done this or if this possible to work.
I have 2.8
2.7T is the engine size same?
if so, is that possible to transplant turbo setting from 2.7 to 2.8?
if the engins size is same, body is same size(like A6 4.2 is wider Iknow)
isn't it possible to transplant the setting, install it, and able to run it?
I know cost would be a lot to do, but I just had it in my mind and see if anyone done it before...
Old Oct 14, 2007 | 12:51 PM
techbod's Avatar
Default RE: not sure if anyone asked...
so you want to replace the engine with a 2.7t? yes it will fit but you need to change the complete wiring loom and the ECU plus other complications
Old Oct 14, 2007 | 02:41 PM
marko_tomas13's Avatar
It is the same size and theoretically could be done.
I hear of a lot of people wanting to do this however they quickly see it would be cheaper to sell the 2.8, buy a 2.7T and mod to their hearts content.
You can however supercharge the 2.8 and well that makes it pretty awesome haha.
Old Oct 14, 2007 | 06:29 PM
auditech79's Avatar
Yeah supercharging it for around $7,000 would be cheaper than to swap a 2.7T into it.
There is an un-imaginable amount of things you would have to swap over/buy to get the 2.7T to run in your vehicle. Not to mention the 30+ hours of labor to do the swap.
Old Oct 14, 2007 | 06:55 PM
project13's Avatar
Sell it and buy a 2.7 or 4.2
Then u will be happy
Old Oct 15, 2007 | 09:23 AM
tahoehtp's Avatar
yeah I just had thought that's all.
and yes I know it's easier to sell the 2.8 and get 4.2 or 2.7t..
supercharger stilllooks like way to go, but really I just had thought in my mind that if anyone done it.
Old Oct 17, 2007 | 12:03 PM
nolyaw's Avatar
get rid of that hood rat 'hoe and put your chips together for something nice
Old Oct 17, 2007 | 12:32 PM
tsbpenguin's Avatar
What about using the turbo layout from the 2.7t on a 2.8?
Could you swap manifolds, turbos, exhaust, intake tubes, etc etc to make a 2.8 twin turbo rather than spending $7000 on a supercharger?
I don't personally have a 2.8, just a thought.
Old Oct 17, 2007 | 05:41 PM
nolyaw's Avatar
Sure continue by changing head gaskets, lowering compression, add more fuel, change the exhaust, and then top it off by putting some cool stickers on it....knuckelheads
Old Oct 17, 2007 | 06:33 PM
auditech79's Avatar
ORIGINAL: tsbpenguin
Not a chance in hell, you would still need an engine wiring harness, ECM, Injectors, intake manifold, throttle body,all the plumbing for the intercoolers, brackets for everything, probablymore.Plus the engine won't hold up under more boost than 10 psi without cracking the rods....... I think.
