Oil pressure light?
Old Oct 1, 2006 | 03:30 PM
zrad's Avatar
Default Oil pressure light?
I just bought a 2000 A6 4.2. It didnt come with the manual. Does this car not have a oil pressure warning light? I might be having oil pressure problems. Valves are noisy when hot. It makes a little rattle when rpms fall only when hot. Audi dealer said cam chain tensioner was letting up. The under lying or route problem could be a oil pressure problem? Thx
Old Oct 1, 2006 | 03:39 PM
techbod's Avatar
Default RE: Oil pressure light?
it does have an oil warning light which should light up when the ignition is turned on check system its not the same as an oil pressure light which would sound an alarm if the pressure was low engine running ( cam chain has nothing to do with that )
Dallas09
Aug 30, 2011 05:57 PM
ArmenB
Oct 11, 2008 12:23 PM
lfab500
Mar 3, 2007 01:33 AM
