oil service indicator
Hi,
Turn off the ignition. Press and hold the button on the left side of the display while turning the ignition on. Service OIL will be displayed. Pull out the button on the right side of the display until the service prompt is cleared. The display should now read.
If this procedure does not work, follow this procedure: With the ignition off, push the right button. Turn the ignition on and then pull the left button. This should clear the warning message.
