Oil Temp Integrated into Oil Level Sensor?
Old Apr 4, 2010 | 06:57 PM
FingerLakes's Avatar
Default Oil Temp Integrated into Oil Level Sensor?
Is the oil temp sensor integrated into the level sensor that is located on the bottom of the pan on my 03 V6? If not, does someone have a image that shows it?
Thanks!!
Old May 12, 2010 | 10:05 AM
Anyone? 03 Avant 3.0 is getting Oil sensor error. Is this the sensor in the oil pan? Thanks!
Old May 12, 2010 | 11:21 AM
hxgaser's Avatar
The sensor at the bottom of the pan is for both the temp and the level for AVK.
What is the exact code? It can be the sensor, wiring or the gauge. All depends.
Old May 12, 2010 | 10:54 PM
auditech79's Avatar
+2, the sensor at the bottom of the pan works two jobs.
1. Oil level
2. Oil temp
Like hxgaser said, check the resistance of the wires to the sensor from the cluster before you replace the sensor.
Old Sep 2, 2015 | 06:37 PM
nlinesk8s's Avatar
Default rockauto
Found it for $82
. I think ill look for a car being parted
vtraudt
Apr 22, 2013 03:24 PM
MyFreeAudi
Apr 26, 2011 07:25 PM
MyFreeAudi
Apr 25, 2011 09:27 AM
Terrynt
Jan 13, 2011 02:09 PM
blackheart
Nov 15, 2006 03:39 AM
