OK got the 0421 Code. Options / suggestions?
Old Nov 29, 2010 | 07:49 PM
urban_legend's Avatar
Default OK got the 0421 Code. Options / suggestions?
OK with the 0421 - I am assuming a bad cat. So I guess I could:
- ignor it
- try some catalytic cleaner
- install a used cat
- try the VAST piggy pipes.
Car (2000 A6 2.7T, 6-speed) has 116K. Some blue smoke on start-up, burns a little oil, and mileage has slipped a little; from 20-21 to 17/18 in the city.
Old Nov 30, 2010 | 04:02 AM
bigdadi's Avatar
Good luck in finding a used cat b/c I think Fed forbids the used cat sale and a $100k fine.
You may check this out www.bigdaddiesgarage.com
Old Nov 30, 2010 | 12:35 PM
hxgaser's Avatar
I think P0421 and P0431 codes are set to come on too soon on our cars. If your mileage is not highly impacted, and you know that the converters are not really plugged, the you may be able to mask the issue by using spark plug anti fouler trick. Otherwise break open your piggie bank.
Old Nov 30, 2010 | 05:21 PM
oldmots's Avatar
Often these codes come from bad O2 sensors. You need to get the car on a real time scanner to monitor the sensors with the car running to see how they are working. They are cheaper than Cats.
Old Nov 30, 2010 | 05:53 PM
bob martin's Avatar
Also, the codes come from bad gas, particularly as the cold weather sets in and causes excess condensation in the underground tanks. My codes went away after a couple of tankfuls of cleaner gas.
Bob
Asterix58
Aug 11, 2012 09:31 AM
cphillips
Jun 22, 2010 03:21 PM
bottlecap
Dec 27, 2009 08:54 PM
pathak76
Dec 12, 2007 03:35 PM
silva
Oct 30, 2006 06:26 AM
