Outer grill cover
Old Apr 21, 2011 | 11:18 AM
vmaxie's Avatar
Default Outer grill cover
I need to replace one of the outer grill covers (also called fog lamp cover) on my 2006 Audi A6. Anyone done this before? Any tips would be appreciated. Thks
Old Jul 7, 2011 | 08:55 AM
hdspringer98's Avatar
Same here, I found a clip that you pop but after that it only partially comes out, can't seem to get the entire cover to come out.
Old Jul 7, 2011 | 03:40 PM
Default Solved
Ok, all the posts and mentions found via Google were not very clear. I did manage to solve it. Here's the real deal: With a screwdriver pop the left side tab and gently pull out the left side of the grill cover. (this is for driver side grill cover). Then there are 2 tabs hidden on the far right of the grill and in some cases if you pull the grill towards the middle they come out....they didn't in mine. So I gently inserted a flathead screwdriver between the bumber and grill cover and gently worked it. Eventually it popped out and revealed the easy to replace fog lamp assembly.
Sheasta
Jul 21, 2012 03:31 PM
Pitts.PAAUDI
May 23, 2009 11:18 AM
hcaudikeed
Nov 17, 2008 03:31 PM
konboy22
Nov 21, 2007 12:36 AM
