p0024
Hey. I've had the p0024 code pop up three times in the past six months. Code reads: "B" camshaft position timing over advanced or system performance bank 2. Open or short circuit condition. Probable cause: poor electrical connection, failed camshaft actuator, blocked oil passage. I replaced the camshaft position sensor twice and the engine light went away. Though extremely weird it would fail a third time, I replaced it again, this time it didn't work. Car pretty much idles rough and a rough start sometimes. Any suggestions on what I can check and probably how to check it before throwing money at the dealer? I do not have a VAG COM. Also, driver side is bank 2, correct? Thanks.
Here are a list of my fault codes if anyone has any intellect on any of them.
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0060
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2A5BEE848559567111F-807F
5 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 61
Reset counter: 40
Mileage: 183042 km
Time Indication: 0
Date: 2014.07.23
Time: 23:13:34
Freeze Frame:
RPM: 864 /min
Mass Air / Rev.: 125.4 mg/str
Temperature: 52.5°C
Idle
Load: 19.2 %
Speed: 0.0 km/h
18975 - Low Pressure Fuel Sensor (G410)
P2543 - 009 - Intermittent - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 16
Reset counter: 38
Mileage: 190988 km
Time Indication: 0
Date: 2014.11.07
Time: 14:35:00
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 163.5 mg/str
Temperature: 73.5°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
16408 - Bank 2: Camshaft B (Exhaust)
P0024 - 008 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 5
Reset counter: 22
Mileage: 191268 km
Time Indication: 0
Date: 2014.11.10
Time: 14:38:59
Freeze Frame:
RPM: 1504 /min
Mass Air / Rev.: 114.5 mg/str
Temperature: 54.0°C
Part Throttle
Bin. Bits: 00000000
Steering Angle: -83.26°
16775 - Camshaft Position Sensor (G301)
P0391 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 17
Reset counter: 22
Mileage: 191326 km
Time Indication: 0
Date: 2014.11.11
Time: 08:51:00
Freeze Frame:
RPM: 800 /min
Mass Air / Rev.: 207.1 mg/str
Temperature: -1.5°C
Idle
Bin. Bits: 00010000
Speed: 0.0 km/h
17944 - Camshaft Timing Adj. Bank2 (N208)
P1536 - 009 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00000100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 18
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 55.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 2D51E598B4B74149F4D-8078
3 Faults Found:
01420 - High Pressure Switch Valve 1 for Electronic Stability Program (N227)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 105
Mileage: 191357 km
Time Indication: 0
Date: 2014.11.11
Time: 12:41:45
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4782
Hex Value: 0x0018
Hex Value: 0xC09E
Hex Value: 0x00FF
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 87
Mileage: 186645 km
Time Indication: 0
Date: 2014.08.28
Time: 07:09:05
Freeze Frame:
Hex Value: 0x5300
Hex Value: 0x4006
Hex Value: 0x001C
Hex Value: 0x90AA
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 3
Reset counter: 87
Mileage: 187414 km
Time Indication: 0
Date: 2014.09.03
Time: 14:54:02
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x002D
Hex Value: 0x0596
Hex Value: 0x00FF
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 730 E HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 360CM057520964
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 234503A0E2738739529-8076
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000126783
Subsystem 3 - Serial number: 0117.03.050000000100010685ÿ
Subsystem 4 - Serial number: 010685ÿ
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 39
Mileage: 191778 km
Time Indication: 0
Date: 2014.11.15
Time: 20:09:17
Freeze Frame:
Bin. Bits: 10
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013123
VCID: 66C35AB451C1B211F57-8033
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
2 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Reset counter: 87
Mileage: 119108 km
Time Indication: 0
Date: 2011.07.21
Time: 10:25:00
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Reset counter: 87
Mileage: 127880 km
Time Indication: 0
Date: 2012.01.04
Time: 14:11:00
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 B HW: 4E0 035 593
Component: SDAR
Serial number: AUZ4Z7E2009120
Shop #: WSC 00000 000 00000
VCID: 26431AB491417211357-8073
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 141
Mileage: 184153 km
Time Indication: 0
Date: 2014.08.04
Time: 01:28:19
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DB175588497F1C924D-8008
2 Faults Found:
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11101011
Fault Priority: 2
Fault Frequency: 206
Reset counter: 214
Mileage: 187408 km
Time Indication: 0
Date: 2014.09.03
Time: 14:54:00
Freeze Frame:
Voltage: 11.28 V
Count: 116
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 187
Reset counter: 118
Mileage: 183040 km
Time Indication: 0
Date: 2014.07.23
Time: 23:13:36
Freeze Frame:
Voltage: 12.84 V
Count: 236
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394CZ057527792
Coding: 0000002
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 105
Mileage: 191357 km
Time Indication: 0
Date: 2014.11.11
Time: 12:05:24
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000004383
Shop #: WSC 02016 444 53358
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1503010386
Coding: 344630393135313035432056413031353033303130333836
Shop #: WSC 00000 384 00290
4 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 134
Reset counter: 255
Mileage: 102941 km
Time Indication: 0
Date: 2010.11.06
Time: 10:12:43
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 121
Reset counter: 255
Mileage: 127879 km
Time Indication: 0
Date: 2012.01.04
Time: 13:54:48
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 111
Reset counter: 255
Mileage: 127879 km
Time Indication: 0
Date: 2012.01.04
Time: 13:54:58
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 110
Reset counter: 255
Mileage: 127879 km
Time Indication: 0
Date: 2012.01.04
Time: 13:55:08
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: 06.00.54 Serial number: 00067811720506
Coding: 0001206
Shop #: WSC 131071 1023 2097151
VCID: 61C949A8B8EFD529005-8034
1 Fault Found:
01543 - Parking Aid Warning Chime (H15)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 217
Reset counter: 250
Mileage: 154495 km
Time Indication: 0
Date: 2013.03.28
Time: 01:59:30
5 Faults Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 61
Reset counter: 40
Mileage: 183042 km
Time Indication: 0
Date: 2014.07.23
Time: 23:13:34
Freeze Frame:
RPM: 864 /min
Temperature: 52.5°C
Idle
Load: 19.2 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 38
Mileage: 190988 km
Time Indication: 0
Date: 2014.11.07
Time: 14:35:00
Freeze Frame:
RPM: 672 /min
Temperature: 73.5°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 22
Mileage: 191268 km
Time Indication: 0
Date: 2014.11.10
Time: 14:38:59
Freeze Frame:
RPM: 1504 /min
Temperature: 54.0°C
Part Throttle
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 4
Fault Frequency: 17
Reset counter: 22
Mileage: 191326 km
Time Indication: 0
Date: 2014.11.11
Time: 08:51:00
Freeze Frame:
RPM: 800 /min
Temperature: -1.5°C
Idle
Bin. Bits: 00010000
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 18
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 55.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Coding: 0020895
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 105
Mileage: 191357 km
Time Indication: 0
Date: 2014.11.11
Time: 12:41:45
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4782
Hex Value: 0x0018
Hex Value: 0xC09E
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Reset counter: 87
Mileage: 186645 km
Time Indication: 0
Date: 2014.08.28
Time: 07:09:05
Freeze Frame:
Hex Value: 0x5300
Hex Value: 0x4006
Hex Value: 0x001C
Hex Value: 0x90AA
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 3
Reset counter: 87
Mileage: 187414 km
Time Indication: 0
Date: 2014.09.03
Time: 14:54:02
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x002D
Hex Value: 0x0596
Hex Value: 0x00FF
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 39
Mileage: 191778 km
Time Indication: 0
Date: 2014.11.15
Time: 20:09:17
Freeze Frame:
Bin. Bits: 10
Coding: 0013123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Reset counter: 87
Mileage: 119108 km
Time Indication: 0
Date: 2011.07.21
Time: 10:25:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Reset counter: 87
Mileage: 127880 km
Time Indication: 0
Date: 2012.01.04
Time: 14:11:00
Component: SDAR
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 141
Mileage: 184153 km
Time Indication: 0
Date: 2014.08.04
Time: 01:28:19
Revision: C63C0030
Coding: 0005022
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 214
Mileage: 187408 km
Time Indication: 0
Date: 2014.09.03
Time: 14:54:00
Freeze Frame:
Voltage: 11.28 V
Count: 116
Freeze Frame:
Fault Priority: 3
Reset counter: 118
Mileage: 183040 km
Time Indication: 0
Date: 2014.07.23
Time: 23:13:36
Freeze Frame:
Voltage: 12.84 V
Count: 236
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 105
Mileage: 191357 km
Time Indication: 0
Date: 2014.11.11
Time: 12:05:24
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 102941 km
Time Indication: 0
Date: 2010.11.06
Time: 10:12:43
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 127879 km
Time Indication: 0
Date: 2012.01.04
Time: 13:54:48
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 127879 km
Time Indication: 0
Date: 2012.01.04
Time: 13:54:58
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 127879 km
Time Indication: 0
Date: 2012.01.04
Time: 13:55:08
Coding: 0001206
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 250
Mileage: 154495 km
Time Indication: 0
Date: 2013.03.28
Time: 01:59:30
