P0332 Knock Sensor Curcuit Low Input (Bank2)
Old Mar 6, 2008 | 08:15 PM
davidp423's Avatar
Default P0332 Knock Sensor Curcuit Low Input (Bank2)
I went to autozone just now and pulled this code. What causes this error code too show up. Can it possibly be due to using 87 (regular) gas when I'm supposed to use 91 (premium)?
Thanks
Old Mar 6, 2008 | 08:51 PM
auditech79's Avatar
Default RE: P0332 Knock Sensor Curcuit Low Input (Bank2)
Its possible but not likely. A knock sensor low imput means that the sensor isn't giving the ECM a signal, or the bolt holding down the sensor is loose.
Old Mar 18, 2009 | 10:09 PM
HarryS's Avatar
The code that is set right now on my A4 Avant 2.8V6 is P1137, but P1139 and P0332 are pending. Is it possible that lacking the knock sensor signal triggers the rich condition?
Oh well, I'll find out tomorrow AM if the sensor is attached or loose. Which side of the engine, by the way, is considered 1 and 2. I am guessing that 1 is the same side as cylinder 1?
Thanks.
shehateme
May 28, 2014 07:45 PM
crp0409
B7 Models
Jan 12, 2014 01:15 AM
HarryS
Mar 22, 2009 11:38 AM
bluesnapper
Nov 16, 2006 09:11 PM
VeGaS
Feb 25, 2006 11:34 PM
