P0348 Code
Old May 24, 2012 | 11:17 PM
budnfrida's Avatar
Default P0348 Code
I have done a search but come up empty. Does any one know what this code means. P0348 Camshaft Position Sensor A Circuit High Input (bank 2) it on a 2001 A6 2.8
thanks
B
Old May 25, 2012 | 06:59 AM
02A6Beau's Avatar
usually due to a short, or a bad camshaft position sensor. check the connection and the wiring. make sure you have good contact and there is no gunk/water/corrosion in the connector. if that all looks good, it is probably the sensor. bank 2 is the driver side (left side) IIRC
good luck
Old May 25, 2012 | 10:28 AM
budnfrida's Avatar
good luck
thanks for the info.
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
