P0441 CEL ERROR
Money is tight right and from what I am gathering this is only an emissions problem, is this true? Will it do any major damge if I wait a few weeks to get this fixed?
I've tried gas gap thing so that isn't doing the trick.
OK retard ( I would not call you that but I didn't want to insult you by using a name you hadn't already used.)
P0441 is Evaporative Emission System Incorect Purge flow.
it will not hurt the motor if you drive it that way butcheck the vacuum hose between the EVAP canister and throttle valve.
