P0441 CEL ERROR
Old Dec 31, 2007 | 05:34 PM
jsemon2's Avatar
Default P0441 CEL ERROR
Money is tight right and from what I am gathering this is only an emissions problem, is this true? Will it do any major damge if I wait a few weeks to get this fixed?
I've tried gas gap thing so that isn't doing the trick.
Old Dec 31, 2007 | 05:36 PM
jsemon2's Avatar
Default RE: P0441 CEL ERROR
also, I'm a retard when it comes to cars. These hoses I'm looking for, are they near the gas tank or under the hood?
Old Dec 31, 2007 | 08:58 PM
NH_USA's Avatar
OK retard ( I would not call you that but I didn't want to insult you by using a name you hadn't already used.)
P0441 is Evaporative Emission System Incorect Purge flow.
it will not hurt the motor if you drive it that way butcheck the vacuum hose between the EVAP canister and throttle valve.
Old Dec 31, 2007 | 09:32 PM
WolfsA62.8Q's Avatar
It shouldn't damage the engine. The emission hoses are around the engine, they get brittle over time, crack easily. I also get the P0441 code if I fill the gas tank too full.
Audi_Sky_77
Mar 29, 2015 06:03 PM
ilovelagar
Oct 22, 2008 12:37 PM
KingBenelli
Jul 25, 2008 07:45 PM
Jorgito
Aug 1, 2007 09:41 PM
konboy22
May 20, 2005 01:39 PM
