Parktronic Sensor or Wiring Failure - 2006 A6
Old Sep 8, 2013 | 12:28 PM
RayPag's Avatar
Default Parktronic Sensor or Wiring Failure - 2006 A6
Group,
The Parktronic now does not work as one of the sensors is bad.
I put the VAG Com on it and all raw readings look OK.
Is there a way to see if it's the module or the wiring before I starting tearing things apart?
Thanks,
Ray
Old Sep 8, 2013 | 02:07 PM
Kevin's Avatar
Common problem. It is probably what Audi calls the horn and we think of as the speaker. I had the same problem a couple of years back and had the dealer replace it.
Old Sep 8, 2013 | 05:14 PM
ManyAudis's Avatar
I believe the VAGCOM allows you to sound the parktronic horn. Give that a try to see if the horn is bad.
mogwai88
Feb 17, 2014 07:23 PM
Waffles
Jan 29, 2012 07:26 PM
drft1
Aug 29, 2010 01:36 PM
Dungar46
Mar 10, 2010 09:30 AM
mishenka77
B7 Models
9
Mar 14, 2009 05:54 PM
