Passenger Mirror Reverse Actuation
Old Dec 16, 2008 | 09:42 AM
gtpr73's Avatar
Default Passenger Mirror Reverse Actuation
After a week at the dealer, my passenger mirror will finally tilt down when the car is put in reverse. The only problem is, it won't return to the normal position once I put the car in drive. If I move the mirror switch back to the "center" selection, the passenger mirror moves back correctly.
Is there some setting I can check to make sure it actuates correctly, or am I forced to back to the dealer AGAIN to get this fixed.
Thanks!
Old Dec 16, 2008 | 01:01 PM
NH_USA's Avatar
A week to fix a mirror positioner and now it dosen't work right?????? Sounds like it is time to find another person to work on your car..
Old Dec 17, 2008 | 05:22 AM
katcoota's Avatar
Just curiosity, is this a feature only in auto transmissions, or does it also exist with manual transmissions? I've got a manual and the mirror doesn't move when I put it in reverse.
Old Dec 17, 2008 | 05:57 AM
Kevin's Avatar
Its on my 05 4.2 AT. I believe that gtpr also has a C6. I don't know if the option was available on the C5.
Old Dec 17, 2008 | 09:17 AM
gtpr73's Avatar
I do have a C6.
It's going back to the dealer as my Homelink stopped working. Checked the fuse and it's OK. No lights when I push any of the buttons.....
Old Dec 17, 2008 | 01:44 PM
Jersey2.7t's Avatar
i have an 01 2.7t AT and my mirrors tilt down when i'm in reverse.
Old Dec 17, 2008 | 01:59 PM
NH_USA's Avatar
It's on the C4
Old Dec 17, 2008 | 03:23 PM
chefro's Avatar
Even the original (1995) 2.8 L A6 model AT suppose to have it, but it works I believe only if the right (passenger side) control button is depressed. When moving the gearshift in Reverse, the mirror should tilt slightly downwards so you can see the curb edge when parking.
I haven't tried it yet, as I wasn't aware of it. However, I always keep the passenger side mirror tilted down anyway, expressely for backing-up/parking purpose. Moreover, I doubt I would take the car to a dealership if the feature quit working. I think it's a feature that you can easily go without... and save the diagnosis/repair funds for something more important...
Old Dec 17, 2008 | 03:31 PM
Coors's Avatar
I have an '01 w/ 6spd maunal. It DOES tilt when the switch is selected to the passenger side mirror and the car is put into reverse.
I have the premium and cold weather package. Maybe its associated with a certain package?
Make sure the switch on the console is switched to the passenger side mirror.
Old Dec 18, 2008 | 02:53 AM
gmatov's Avatar
Chefro,
Do you not think you should go to the dealer for such a thing as a non-tilting mirror because it is too little to worry about? If it is under warranty, there is NOTHING too picayune to have attended to. They warrant it, they will fix it.
Else, why pay FOR a warranty?
Cheers,
George
