Plugs on back of head
Old Jan 6, 2011 | 05:57 PM
Jackmup's Avatar
Default Plugs on back of head
I have to replace 1 of my black plastic plugs it's leaking. I don't have the replacement yet do they just pop in and out with a screw driver?
Old Jan 6, 2011 | 06:11 PM
bob martin's Avatar
You have to remove the valve cover and loosen the last cam cap.
Old Jan 6, 2011 | 07:54 PM
Jackmup's Avatar
Thanks
It's never easy.
Old Jan 7, 2011 | 03:43 AM
chefro's Avatar
+1
Jack, there's your chance for new vc gskets too.
Old Jan 7, 2011 | 06:41 AM
bob martin's Avatar
Actually, its worse that that, now that I think about it. On the drivers side, it is just the full circle plug and all you have to do is remove the valve cover, loosen up the last cam cap and replace the seal. On the passenger side, the can chain tensioner is on the back of the head so you will need the cam chain tensioner compression tool. You have to replace both the half moon seal and the cam tensioner seal. You could try the shortcut but it didn't work for me. The long method is to remove the cams, for which you need to remove the timing belt. The in between method is to clamp the TB to the cam gear and just remove all the cam caps. In any case, it is a ridiculous amount of work to change a seal that should have been 100% inside of the valve cover gasket so that a leak wouldn't matter. But, this isn't a Toyota....
Old Jan 7, 2011 | 10:39 AM
hxgaser's Avatar
^^ Ditto. If your cam chain tensioner gaskets are not leaking, you technically don't need to remove the valve cover. Audi has "super special" extraction tool for the cam seals, but not for the plug. Screw driver with a sharp point tip will work. If you are opening up the valve covers, then you might as well as do everything in the back including the cam chain tensioner gaskets.
Old Jan 7, 2011 | 11:37 AM
nemohm's Avatar
The driver's side requires - pop out - drive in.
Clean the well, no silicons...
Cold engine, cold plug (might freeze it).
Engine off at least overnight.
Old Jan 7, 2011 | 01:59 PM
Jackmup's Avatar
This is the passenger on my 4.2.
I have the cam tool but have heard some people can stab them and yank them out. I should have done it with the T/B service when I did the 1/2 moon gaskets and cam adjuster gaskets but they weren't leaking at all.
That was in FL though now that I'm back in NY all this plastic is shrinking in the cold.
No big deal Just wanted to plan my time. As if a simple repair on an Audi ever took less than a perfectly good weekend. The hard part is finding those damn plugs after a 1500 mile move.
Old Jan 7, 2011 | 08:53 PM
chefro's Avatar
Are you back in NY? Damn....
Sorry for my rush into agreeing with Bob, but that's how I did mine. However, I always forget that I may be among the scarce few that have this pos C4...
Trigger200
B7 Models
Aug 16, 2015 09:35 PM
AudiTurbo
Jan 7, 2014 08:03 AM
Jackmup
Jan 15, 2011 02:06 PM
dtb2253x
Sep 23, 2010 11:50 AM
rmongo
Nov 20, 2005 06:11 PM
