Poor headlights a6
Old Apr 8, 2007 | 12:19 PM
seahunter's Avatar
Default Poor headlights a6
dear friends, i am the not sure to say happy owner of a 98mod a6.
the headlights on this model is bad, i want to change for something better, but not sure of a good substitute, therfore i am adressing this forum, for advice on what to change to.
thanks in advance
"suffering a6 owner in Norway"
Old Apr 8, 2007 | 05:40 PM
GIAudi's Avatar
Default RE: Poor headlights a6
Do you have HID's now? If you do, upgrade the bulb to a 6000k helps some. If not you have to get better bulbs and make sure the lenses are polished. I have to polish mine and reports are it makes quite a difference.
Old Apr 8, 2007 | 08:10 PM
01A4T's Avatar
4300k HID will get you the best visability of any temp. xenon.
Old Apr 9, 2007 | 05:39 AM
XrichTHEdudeX's Avatar
those guys are right about the xenon lights but if you don't want to spend the money and time installing a kit, PIAA bulbs work really nicely as well. They're like $70 for a set. Just make sure when buying aftermarket bulbs that you get the correct wattage ones. 55w is OEM on that model. Any higher will burn up your wires and you will have a shitty problem.
Old Apr 9, 2007 | 01:22 PM
NJ@BoroKidA6's Avatar
HID's are definately the way to go. My brother put HID's in his truck and they were rated at 5000K, and all i can say is that they were BRIGHT! Try to find a rating between 5000 and 6500k.
Old Apr 9, 2007 | 06:41 PM
01A4T's Avatar
anything with a temp higher than about 43-4500k will not produce as much visable light. They will look blue or purpleish.... they look kinda nice but when you get up to 6000k or higher, the less light you will have to your advantage. My advice is to go with 4300K HID's
Old Apr 10, 2007 | 08:06 PM
Jeffla's Avatar
I have 6000k HIDs right now, but have 4300k bulbs on there way. The 6ks look purplish blue in the fixture and blueish white on the road. I regret having bought the 6ks in the first place. Get yourself some 4300k hids off ebay for 140.00 dollars and get it over with. Anything else and you will be dissapointed, I always was.
Jeff
Jason Benson
Jul 21, 2013 09:23 AM
armyboy91083
Feb 14, 2010 09:50 PM
aberfitch82
Oct 30, 2007 04:52 AM
