Sponsored by:
Sponsored by:
Is it possible to add memory seats?
Old 07-30-2009, 07:20 PM
gone postal's Avatar
Location: Nation's oldest city, FL (screw you Jamestown)
Default Is it possible to add memory seats?
This is the only option I REALLY wish I had - mainly b/c my wife is 5'4" and I'm 6'2", so EVERYTHING gets adjusted when she drives the car (which i'm trying to put a stop too ). Anyway, since my seats are electric, is the wirring / harness already in the door? I found a matching door panel, but don't want to spend the $100+ if there is no way it's gonna work. I'm assuming there is some sort of control box? Is that built-in under the switches or located somewhere else? Does anyone have a Bentley and confirm if there is a harness already in the car or is it just an extra one that runs from the switches to the seat or is it more integrated (ie - "pain in the a*s") than that?!? I have a VAG-COM, so any programming (if needed) isn't an issue.
Old 07-30-2009, 11:05 PM
chefro's Avatar
Originally Posted by 8059350957375
Old 07-30-2009, 11:17 PM
Midniteoyl's Avatar
haha!
Old 07-31-2009, 07:03 AM
Kevin's Avatar
Originally Posted by chefro
Very funny.
Old 07-31-2009, 08:11 AM
bob martin's Avatar
You will need to replace the wiring harness in the door, the wiring harness under the dash, the wiring harness running to the seats and the seats themselves. It would be easier to trade your car in for one with this option. I'm sort of in the same boat and I looked into this as well.
Bob
Old 07-31-2009, 12:57 PM
Jeffla's Avatar
Bob
x2
Jeff
Old 07-31-2009, 08:17 PM
Are you serious - different seats??? Wow. I figured that instead of the seat getting the signal from the joysticks, it would just get it from a control box which is obviously programmed w/ the memory settings. I thought for sure I'd just be replacing the regular harness w/ another one and adding the new door panel. It's amazing that a company would make so many things different over a simple option - seems cost prohibitive
Old 08-01-2009, 07:23 AM
bob martin's Avatar
You are correct, there is a "control box" and that "box" is in the seat! Hence, you would need new seats. But, you could get those out of a junkyard vehicle. It's replacing the dash wiring harness (power and fuses) that will cost you.
Bob
Hook Shot
08-27-2011 08:23 PM
xbimmer
04-15-2008 05:34 PM
moreno_g2003
09-09-2007 05:00 AM
tjolson19
06-20-2007 06:08 PM
keko2004
11-09-2006 12:56 PM
Quick Reply: Is it possible to add memory seats?
