Possible fan problem
Old Feb 8, 2008 | 10:07 AM
JcoyA6's Avatar
Default Possible fan problem
I am not sure what the problem is, but every once in a while it is like some system turns on and it sounds like a fan of some sort is rumbling, then the system cuts off and it goes away and the car sounds perfect. Any ideals?
Also yesterday for a minute or so the smell of burning plastic came through the vents, wierd
Old Feb 8, 2008 | 01:32 PM
auditech79's Avatar
Default RE: Possible fan problem
Its probably your SAP (secondary air pump) going out. They usually turn on when the engine is first started. (kinda sounds like a vaccum cleaner when they go bad)
Old Feb 8, 2008 | 01:36 PM
techbod's Avatar
very common on most cars of today ( secondary air injection ) mine buzzes a bit but normal on cold starts
Old Feb 8, 2008 | 04:02 PM
NH_USA's Avatar
If the vehicle has been run for awhile it might be the auxilary cooling fan for the radiator. The usually happens after driving for awhile andthen idling in traffic etc. or going slowly without a lot of air passing through the radiator
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
