Power Steering ?
Old Dec 4, 2007 | 02:45 PM
JoJo03's Avatar
Default Power Steering ?
Is it normal to see bubbles when you take off the power steering capfrom the container while the car is running?
Old Dec 4, 2007 | 02:49 PM
techbod's Avatar
Default RE: Power Steering ?
no because the fluid level could be too low or you have a leak ( top it off )
Old Dec 4, 2007 | 04:33 PM
AZAudiA6Q's Avatar
What kind of power steering fluid do the A6's use?
Old Dec 4, 2007 | 09:50 PM
catdog's Avatar
Important, mineraloil base. Pentosin or Febi. Dealer or www.ecstuning.com
Old Dec 4, 2007 | 10:11 PM
JoJo03's Avatar
What kind of symptons would you get if you do have a leak in the power steering system?
Old Dec 4, 2007 | 10:32 PM
99A6Q's Avatar
If the power steering reservoir is full and you are seeing very small bubbles that is normal, just from the fluid flow. Top it off if it is low. Symptoms that you might encounter if your system has a leak in it/you are low on fluid is moaning sounds when you turn the steering wheel(especially right after start up when the car is still cold).
Old Dec 4, 2007 | 10:40 PM
JoJo03's Avatar
thanks for that information 99A6Q, really helpful.
a3turrell
Jan 14, 2012 05:23 AM
Lastb0isct
Feb 17, 2009 03:15 PM
Kobe Diesel
Feb 20, 2008 10:38 PM
