Power steering fluid flush....?
ORIGINAL: auditech79
The power steering fluid from Audi is mineral based and evaporates over time so you don't really have to flush it, just keep topping it off.
By the way, my local Audi dealer quoted $489 to flush the tranny!
Question, is there any fluids other than Audi fluids that can be used such as for brake, rear diff, for example?
The rear diff just uses syntheticCastrol 90 weight gear oil, nothing too special. You can pick that up at any store.
For the power steering i wouldn't stray from the factory mineral oil,i don't believe there is a drain for the power steering, if needed we will stick a tube down the resivior and vaccum out as much PS fluid as possible, top it off, then aerate the system by turning the wheel back and forth until the bubbles in the resivior are gone.
