Flush and bleed power steering system
Old Jan 26, 2008 | 09:55 AM
Trey25's Avatar
Default Flush and bleed power steering system
How do I bleed the power steering? The lines to the oil reservoir were replaced and I think they put in the wrong oil. Is the stuff they sell at autozone for example the same as the oil sold at the audi dealership? If its anything like the coolant requirement I'm guessing no.
Old Jan 26, 2008 | 02:22 PM
CRAZYHAWK's Avatar
Default RE: Bleeding power steering
You need Pentosin 11S. If you used the wrong stuff, have it removed.
You might cause the steering rack seals to leak.
Old Jan 27, 2008 | 04:11 AM
Trey25's Avatar
Yea thats exactly why I'm asking the question how do you bleed the system.
Old Jan 27, 2008 | 09:48 AM
Redrum1's Avatar
Start with filling the reservoir with Pentison 11S. Get the front wheels off the ground and turn the steering wheel back and forth from lock to lock 3 or 4 times. Check the fluid level again and top it off if needed. Then start the engine and do the same procedure till all air bubbles and pump groaning go away and check fluid level again. At this point you should check for leaks and you should be good to go. Take it for a ride and check fluid level for the last time.
Good Luck.
Old Jan 27, 2008 | 03:27 PM
Trey25's Avatar
Default RE: Bleeding power steering (I mean flush the system)
Sorry guys I messed up. I meant FLUSH the entire system. How about disconnecting the return line to the reservoir and fill with new fluid at the same time?
catdog
Apr 3, 2013 08:37 AM
IDUA ORTTAUQ 6A
Sep 13, 2007 04:48 PM
less_of_me
Jun 8, 2007 01:11 PM
jimmyt853
Jan 11, 2007 02:29 AM
1.8t20v
Jul 10, 2005 11:29 AM
