Sponsored by:
Sponsored by:
power steering pump diagram
Old 12-12-2007, 03:27 PM
catdog's Avatar
Default power steering pump diagram
Does any one have a diagram of the steering pump?
Old 12-12-2007, 10:53 PM
catdog's Avatar
Default RE: power steering pump diagram
bump
Old 12-13-2007, 09:38 AM
catdog's Avatar
Any suggestions where I might find a diagram or expanded view?
I've search online.
The piston is moving smoothly but pressure will not build up. I mean no pressure.
Old 12-13-2007, 10:49 AM
maxims45's Avatar
Member
I have not seen any manuals on that. On mine A6 C4 the pump is composed of two parts - you can easily disassmble it and replace sealings.
Check its belt as well - does it rotate at all? What do you mean by piston moves smooth?
Old 12-13-2007, 12:55 PM
catdog's Avatar
There's a small piston on the pump that was stuck and scored, caused a lot of noise.
whitey
05-21-2009 10:30 AM
Darivative
11-04-2008 09:37 AM
Datsundrift
05-09-2008 12:12 AM
pimptrooper3000
01-01-2008 12:39 PM
Quick Reply: power steering pump diagram
