PowerSteering Question Need Help
Old Aug 24, 2010 | 03:33 PM
05a6ct's Avatar
Cool PowerSteering Question Need Help
So the past few weeks i have been hearing noise when i turn either which way in my 2005 A6 3.2, so today i took a sharp down hill turn into a plaza and the noise got really bad but then its slowly went away, when i got home i checked my fluid level and when i opened the cap it was dry not a drop in there. idk what to do am i checking it the right way?
p.s i just had my car serviced at audi last week shouldnt they top off all fluids?
Old Aug 24, 2010 | 09:40 PM
Jeffla's Avatar
You need to add fluid, if you can't see any, then that is not good. How you measure the level, I don't know on a C6. I would not drive the car with no fluid in the reservoir.
Old Aug 25, 2010 | 11:54 AM
bob martin's Avatar
Keep in mind the fluid is Audi specific. If you put in regular power steering fluid, you will have to replace the rack.
Once you refill it, you have to chase down the source of the leak. Since you appear to be a "take it to the dealer" kind of guy, I would try your approach of complaining to the dealer that he was supposed to top off the PS fluid and he didn't and maybe he will do the inspection for free.
Good luck,
Bob
Old Aug 25, 2010 | 02:34 PM
DMC's Avatar
DMC
I had this same issue with my '05 4.2 twice. The dealer eventually tracked it down to loose pressure hose at the rack itself. Definitely need to use the Audi specific fluid.
Old Nov 13, 2010 | 12:56 AM
02A4kid's Avatar
does anyone know what that specific fluid is? and where to get it?
Old Nov 13, 2010 | 08:11 AM
02AudiA63L_65's Avatar
In the Bentley service manual for '98 to '04 (A6 - RS6), it specifies Audi spec - G 002 000. But, as Bob stated, always check with the Audi dealership and keep the receipts just in case they make a mistake. . .
Old Nov 13, 2010 | 09:32 AM
Kevin's Avatar
Here is a link to the specified fluids for your car http://uberlame.com/a6_tsb/Miscellan...05%20fluid.pdf
The fluid specified is G002 000
2001A6
Sep 15, 2009 05:45 PM
aberfitch82
Oct 24, 2007 02:59 PM
pyrotechnique
Sep 18, 2006 09:01 PM
