Problem please help!
Old Oct 15, 2007 | 06:45 PM
97A612v's Avatar
Default Problem please help!
i recently did the water pump on my 97 a6 12v.. when i took off the timing belt i forgot to note the position and mark anything.. everyhting has been moved form the position it was in.. how can i replace everythign to make sure i get the timing correct?
Old Oct 15, 2007 | 06:58 PM
auditech79's Avatar
Default RE: Problem please help!
You NEED the cam lock bar to lock the cams together, the timing can't jump with that tool installed.
As for the crank, the pulley is keyed meaning if you put the lower timing cover back on with the pulley you can see the timing mark. But that means nothing if you don't know where the cams are, buy that tool!
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
