Problems getting into reverse
Old Dec 24, 2013 | 06:33 PM
Infinity_UK's Avatar
Default Problems getting into reverse
Hi Everyone,
First of all Merry Christmas!
More problems with my car! I have a 2006 Audi A6 7 speed Auto 2.0 Diesel.
While driving the other day the engine management light came on. Everything seemed fine while driving. I parked up thinking it was glitch hoping the the error would clear by the next day but it did not. The next day I could not put the car in reverse. The gear lever oult not get out of park, so I used the override button near the gear lever and was able to get the car into gear. I managed to get out of my drive, but later on in a car park I tried to reverse into a parking space and put the car in reverse. As I tried to accelarate and the engine just reved and the car hardly moved. After around 5 seconds the beeped into reverse and let me reverse.
I did some testing. I tried to put the car into reverse and sometimes it took a good 5-10 seconds before I heard the reverse beep and the car engaged into reverse. A few times it really clunked/jerked into gear. I seems like I have to put it in gear and wait a bit before trying to reverse.
I managed to get a diag done on the car and it showed the following. I did get the codes cleared thinking it may sort the problem out but it did not:
Address 01: Engine Labels: 038-906-019-AJM.lbl
Part No: 038 906 019 LR
Component: 1,9l R4 EDC G001AG 1565
Coding: 00001
Shop #: WSC 00020
1 Fault Found:
17965 - Charge Pressure Control
P1557 -- 35-10 - Positive Deviation - Intermittent
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: None
Part No: 09B 927 750 L
Component: AG5 Getriebe 09B 0248
1 Fault Found:
00300 - Transmission Fluid Temp. Sensor (G93)
27-10 -- Implausible Signal - Intermittent
After getting the codes cleared and drivng the car for a few day I got another diag done, but nothing showed up as an error, bit I still have the problem.
Any ideas on how to fix this problem?
Thanks
Old Dec 25, 2013 | 02:04 AM
Nebuchadnezzar's Avatar
I would tend to believe that the transmission fluid temperature sensor is faulty / acting up, which is more of less putting your TCM into some type of safe mode because it can't determine how much or how little fluid is in the transmission. You might be thinking how temperature is related to how full of under filled the unit is. When refilling an Audi transmission, it is actually done from below the car without a traditional dipstick. So when doing the process one must use the temperature of the fluid as a guide to when add more fluid so it's full.
The torque converter and basically the entire transmission is heavily dependent upon fluid. It's actually pretty amazing how the how thing works when you see a video on just what is inside of the unit. In short, the fluid in an auto transmission is the life blood of the unit. Without it the unit will not function correctly, which is what you are most likely seeing here.
Old Dec 25, 2013 | 11:43 AM
Thanks! I had my fluid changed a little while ago and check just a month ago.
Hi
I did a recan but not an auto one, and got something very different.
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4F1 910 155 H HW: 01J 927 156 JG
Component: V30 01J 2.0l PD RdW 0040
Coding: 0000001
Shop #: WSC 12345 123 12345
1 Fault Found:
001798 - Transmission Range Sensor (F125)
P0706 -- 000 -- Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 8
Mileage: 81527 km
Time Indication: 0
Date: 2013.12.17
Time: 16:50:55
Freeze Frame:
RPM: 96 /min
RPM: 0 /min
(no units): 1.0
Torque: -26.0 Nm
Temperature: 48.0°C
T.B. Angle: 0.0°
Bin. Bits: 0001 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H05 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020856
Shop #: WSC 02325 785 00200
1 Fault Found:
01119 - Gear Recognition Signal
000 -- - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 113
Mileage: 81527 km
Time Indication: 0
Date: 2013.12.17
Time: 16:50:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0031
Hex Value: 0x0197
Hex Value: 0x00FF
Different error now
Byron88
May 7, 2010 09:39 AM
shadyr78
Dec 11, 2007 01:28 PM
thejobcoach
Sep 16, 2006 03:24 PM
bgadit87
Apr 27, 2006 12:53 PM
RUGBY23
Nov 17, 2005 06:13 PM
