Question about ignition swith R+R.
Is it possible to replace the ignition switch without removing the steering wheel on a 98 2.8 A6Q? I tried removing it yesterday and broke a socket trying to get the bolt loose. So right now it's either try replacing it without the steering wheel off or take it to the stealership.
Thanks.
Thanks.
I thought that the ignition switch was on the dashboard on a 98 Audi and you could change the switch mechanism without removing the steering wheel. There are two parts of the switch -- the mechanical part with the steering wheel and auto trans lockout and the electrical part that has the contacts. But I might be wrong
NO, I didn't because I was afraid of getting something electrical wet. I guess I could try some PB Blaster on it and let it soak for a couple of days...try again next weekend.
What liquid penetrate did you have in mind?
aztempe00
Aug 27, 2008 01:30 AM
