Sponsored by:
Sponsored by:
Question about replacing Cam Plugs on 2.8L.
Old 12-30-2008, 12:09 PM
madridlover's Avatar
Question Question about replacing Cam Plugs on 2.8L.
Is there anyway to "easily" replace the cam plugs on a 2.8L engine WITHOUT removing the valve covers?
I've already replaced my vavle cover gaskets with half moons and cam adjuster seals but I still have burining oil smell. I verified that my cam plugs are leaking.
Anyone?
Old 12-30-2008, 01:17 PM
auditech79's Avatar
If you can't get them out using a pic then taking off the valve cover is the only way to get them out. If the valve cover gaskets aren't that old it should be ok if you take them off and put them back on. When the gaskets get old they start to fall apart. I would say less than 10k would be ok to take the valve covers off.
Old 12-30-2008, 01:39 PM
Yeah, it's been less than 10k miles. So I can resuse but I just need to make sure to re-apply RTV sealant at the 4 corners correct?
Old 12-30-2008, 01:51 PM
One more question. When I remove the valve covers someone mentioned loosening the cam bolts to get the cam plugs to fall out. Are these "bolts" the ones that hold the cam adjuster seals in place?
Can you see the cam plugs inside the engine or is it shrouded?
Mya407
05-02-2012 11:25 AM
Mr_GoodKat
04-08-2010 01:15 PM
a224932
10-04-2008 03:07 PM
chaos92287
12-09-2007 07:50 AM
chaos92287
12-09-2007 07:50 AM
Quick Reply: Question about replacing Cam Plugs on 2.8L.
