question about valve cover gaskets
Old Feb 11, 2007 | 07:07 AM
pkhuman78's Avatar
Default question about valve cover gaskets
I just bought a 2000 A6 2.7T that has 90K miles. Overall, the car was maintained fairly well - regular oil changes and typical service. I am getting ready to replace the valve cover gaskets on it as well asthe suction pump (which I'm pretty sure caused the vlave cover leak) and spark plugs.
While I have that much apart is there anything else I should consider replacing?
A "buyer's check" @ the local stealership revealed that my secondary air pump is weak?
Also, what is the general concensus on oil? @ 90K should I go synthetic or is there a certain weight/ viscosityI should go with?
Thanks for the input.
Old Feb 11, 2007 | 03:57 PM
modset's Avatar
Default RE: question about valve cover gaskets
tou might also want to replace the cam chain tensioner gaskets. those are notorious for leaking.
Old Feb 11, 2007 | 04:06 PM
techbod's Avatar
very dubious ( secondary air pump weak?? ) now how do they make this decision ( have they done tests on the engine?? ) if so what was the results.
could it be your rocker cover gasket bolts need nipping up like 8lb-ft
Old Feb 11, 2007 | 06:37 PM
modset's Avatar
dave- where are the rocker cover bolts located? I have a bentley's but can't locate it. Sorry. maybe a dumb question.
Old Feb 12, 2007 | 12:24 AM
pkhuman78's Avatar
Thanks for the info...any other items come to mind please let me know. This is not a job that I want to repeat if I can keep from it.
I've got the Bentley's manual on it's way so knowing where the rocker cover bolts are located will definately help.
Thanks again.
Old Feb 12, 2007 | 02:55 AM
duckman's Avatar
dave quik question ,,,by the rocker cover bolts do you mean the hold down bolts? do they loosen and a retighten could stop the leak ? and i keep reading about tensioner gaskets but looking at the bently i didn't see them ,or missed them ?
Old Feb 12, 2007 | 02:32 PM
madridlover's Avatar
Do a search on www.audiworld.com for replacing camchain tensioner gaskets. They are notorious for leaking.
mradams316
Oct 16, 2011 11:47 PM
fowvaydriver
Aug 1, 2011 10:46 PM
06AFOUR
B7 Models
Jan 5, 2011 03:33 PM
A6 Quattro V6 30V
Sep 19, 2007 11:57 PM
Audi_Fizzle
Mar 29, 2007 03:11 PM
