Question Car shudders just after startup since doing a carbon cleaning
Old May 18, 2015 | 11:32 AM
techy101's Avatar
Question Question Car shudders just after startup since doing a carbon cleaning
Hey all,
I'm hoping someone on here can offer some advice. I did a carbon cleaning on my 2007 A6 Avant 3.2L (using THIS guide) the other week and have run into a problem. A couple of days after I finished the cleaning I noticed that the car had trouble turning over. It would start then the RPM's would bog way down, the car would shudder a bit, then it would return to normal.
In the two weeks since the problem has gotten progressively worse. Now the car starts, but then shudders for a minute or so of revving before finally returning to normal. When this ends it runs butter smooth and I have no more issues.
The problem only seems to occur when the car gets hot sitting outside. On colder mornings it fires up without a problem. I'd thought maybe I didn't hook a fuel line up tightly enough or something so took the upper intake off again and disconnected/reconnected the fuel rails again and reassembled everything. I also took the time to put in new spark plugs since they were coming due, but unfortunately neither of these things made any difference.
I would appreciate any help in finding the mistake(s) that I made.
Old Jul 31, 2016 | 07:02 AM
cold_surfer's Avatar
Run a complete bottle of the concentrated lucas FI cleaner, PLUS 12 ounces of the regular lucas FI cleaner. Run through the whole tank of gas without refilling. try that out.. -- check with an unlit propane torch to see if there is a vacuum leak in lines or fittings.
jdaudi
Jun 26, 2011 10:11 PM
playboy00786
Jan 24, 2010 06:59 AM
JCatt9
Apr 15, 2007 11:02 PM
DaGimp
Dec 31, 2004 03:40 PM
