Quick Coolant question.. need help asap!
Old Nov 5, 2013 | 05:50 PM
GeondrayPeterson's Avatar
Default Quick Coolant question.. need help asap!
Hi I have the 2.7t it takes the pnk coolant g13 i believe i cannot get any now.. the car is running on water it should freeze tonight will it harm my car any if i put green coolant in there? the peak 50/50
Old Nov 5, 2013 | 06:18 PM
Nebuchadnezzar's Avatar
Audi doesn't advise using anything but G12 or G13. I suppose you could put green in there and flush the system several times in hopes of getting all of that crap out. I certainly wouldn't leave it in there for a long period of time. Oh, and make sure the system has been purged of all G12 or G13 coolant prior to adding green stuff.
Or an alternative would be to drain the system tonight and let it sit empty and then refill tomorrow prior to use and then drive to get the proper coolant.
Old Nov 5, 2013 | 06:51 PM
OGBULLYLOCDAWG's Avatar
Do not mix the green coolant with the G12/G13. From what I've read they react negatively when mixed and turns into a chocolate milkshake like substance.
That's a good suggestion by Nebuchadnezzar. Drain it. Refill in the morning.
Where is the coolant leaking out?
Old Nov 5, 2013 | 06:55 PM
Also, do yourself a favor and mix it with distilled water as tap water or spring water will contain minerals that may allow the system to rust / deteriorate over time.
A4Cragman
Apr 17, 2011 05:02 PM
nova_ss672001
Oct 19, 2010 08:24 PM
juice88
Jul 13, 2006 02:23 PM
jimmysA4T
Aug 26, 2005 03:10 PM
CaliA4
Mar 31, 2005 01:28 AM
