QuicK question
So my idle has been running at about 700 rpms, it seems a little rough and I was just seeing if this could be a problem I should have looked at when I take it in next week. I have it APR tuned and new DV valves so I'm not sure if its that or something else. It also seems to be eating gas as off late. Thanks for the help in advance.
Jason
Jason
APR tuned and new DV who did it and how long ago?? was it running ok after they did it?? and how long has the problem been there, I assume you have checked the obvious like bad vacuum pipes and air leaks, info on the car might help ( 4.2 ) manual tranny that sort of thing and age
Its a 2.7 2000 A6 the tune was done in April by 2Bennett audimotive in Davis. This has been happening for a while and it was before the tune. Its an tip, unfortunatly.its got 70k on it and it goes in for a t-belt change this week along with a new axle and secoondary water pump. Also do you know the part number for the coolant tank and any hoses linked to it, I was going to change those out because of wear.
How about a part 2
What are good ideas for suspension upgrades? Recommendation on shocks/struts/springs
Any recommendations for a boost guage?
Any other upgrades that can be done while they are doing the t-belt/secondary water pump and axle?
Thanks again.
How about a part 2
Thanks again.
