Quick Rotor/Pads questions...Need some advice!
So I decided to change my rotors but can't figure out which ones to get.
Do I need the drilled/slotted rotors or will the plain cheaper ones do fine?
Now as for the pads, do i need the ceramic ones, or can I use some other ones, like those Axiss ones?
I found some zimmerman's on ebay for like 175 drilled and slotted, but again i dont want to spend extra money if I dont need to?
Thx guys
Thx guys
I can't comment on your car in particular, but in general:
Drilled = helps cooling (and looks cool too!), can wear/warp faster due to there being less surface area due to the holes.
Slotted = helps out braking considerably by constantly exposing new brake pad material (acts like a cheese grater on the pad), but at the expense of going though brake pads faster.
As for the ceramic pads, I can't comment from actual use, but I believe they generally will "squeak" more than organic or semi-metallic pads. Unless you're really flogging the crap out of your car and getting the brakes *really* hot, ceramic is likely overkill. Plus, the harder the pad, the faster your wear your rotor.
-Red
-Red
