Radiator Fan Control
Old Nov 5, 2008 | 08:20 PM
prdaga's Avatar
Default Radiator Fan Control
I just purchased a 2006 Audi A6. I have a problem with the radiator fans. If the car is running both of the fans work constantly and once i shut the engine off they continue to run for another minute before they shot off. If the car is turned off and i just open a car door the fans start working and they work for couple of minutes before they shot off. Does anybody know what this could be. I am thinking that it is the fan control unit but i like to hear from you guys.
Old Nov 6, 2008 | 05:57 PM
nemohm's Avatar
Isn't the car still in warranty?
The fans work after the engine is off for a minute?
Then they stop?
But if you open a door (any door) the fans are on again?
Is that what happens?
The fan run on for while after the engine is off on my '86 4kq.
I do not notice similar behavior on my '03 2.7.
Old Nov 7, 2008 | 06:35 AM
prdaga's Avatar
No Warranty.
The fans work constantly while the engine is on (never turn off) and they work for a minute after the engine is turned off.
If i am out of the car and open the door both fans turn on and run for couple of minutes with the engine off before they shot off.
Old Nov 7, 2008 | 11:16 AM
nemohm's Avatar
Is there any difference with AC/Heating "off" or "on".
It's normal to expect fans on with AC/Heating on.
There is a fan control switch located in front of the radiator - left side (passengers side).
There should be a relay as well ( have to look into diagrams).
Any codes BTW?
Old Nov 8, 2008 | 03:47 PM
prdaga's Avatar
I purchased the fan control module and replaced it myself and everything is working fine know. Dealer wanted $400 for labor to replace the module. It only has four colored wires which i just spliced together (took me 20 minutes)and am proud to say, saved $400.
neomaxddr
Mar 28, 2009 07:16 PM
cvacc411
Jan 29, 2009 04:58 PM
