radiator fan fuse?
my 97 quattro has a biggie, 80 amps, (mechanic advised shoudda been 40) located against the left wall in the drivers' foot well. some are just left of the brake pedal above the inside dash bottom covers. good luck.
You will have to drop the driver side lower Dash cover,I've done it a long time ago and forgot how many screws there was,but it was easy for me.and when you remove it,it's right there a big ole fuse.my fan wasn't spinning when I had my a/c on causing my car to over heat,I replaced it and it worked like a charm
neomaxddr
Mar 28, 2009 07:16 PM
cvacc411
Jan 29, 2009 04:58 PM
