Radiator Replacement 1997 A6 Quattro
Old Aug 24, 2010 | 08:08 PM
GFs1997A6's Avatar
I am in the process of pulling my radiator to get it flushed after getting clogged when the GF put glycol in it instead of the G12. I am having trouble finding all the bolts to remove the front bumper. Any tips would be greatly appreciated. Thanks! I found this: https://www.audiforums.com/forum/sho...t=front+bumper
Old Aug 25, 2010 | 08:22 AM
padog's Avatar
It would help if you included the year of your car but if its a C5 then there arent really alot of bolts to remove. remove the front tires and remove the bolts from the front of the inner wheel wells pull the wheel wells back so you can get in to remove the three 10mm nuts on each side. pull out on the bumper where it meets the front wheel well to unclip the bumper from the fender. Remove the two outside grills in the front of the bumper the ones with the foglights in them just give them a tug they will pop out. Inside of the hole where the grill is going straight up through the bumper support is a bolt with a t45 torx head remove this bolt on each side and the bumper should pull out you will then need to unhook the horn and foglight wires and the hose for the headlight washers being carefull not to break the clip on this.
Old Aug 26, 2010 | 12:35 PM
GFs1997A6's Avatar
Thanks I figured it out after finding the correct pdf in the bentley manual. The hardest part was figuring out how to remove the lower grills in order to reach the bumper bolts. Oh and GFS1997A6 = Girlfriend's 1997 A6. It's a nice car but after all the trouble I've had doing maintenance on it, I don't think I will ever own an audi myself.
Now on to the next challenge, all this was to flush the cooling system after she added the green coolant. I made the mistake of trying to start it with the hose attached to the inlet to flush the system. I forgot about the tranny cooler lines and shot a quuart or so all over the garage before shutting it off. Now I get to read up on tranny fluid filling and changing. This is not a fun project. [/hyjack]
Old Aug 27, 2010 | 08:33 AM
padog's Avatar
Well if you didnt like the radiator job then you are really not going to like the tranny! whatever you do follow the directions in the bently to the letter on this one as these trans are very fussy and having the correct level is of utmost importance!
Old Aug 27, 2010 | 04:04 PM
NH_USA's Avatar
padog's comments plus
-- Pay attention to HIM!
Do it right or be sorry! --
Old Aug 28, 2010 | 11:49 AM
GFs1997A6's Avatar
I found this thread, https://www.audiforums.com/forum/sho...d.php?t=125517 plus I have the bentley instructions so I hope it doesn't give me too much trouble. Off to the garage now. Wish me luck.
luckyjack1983
Nov 10, 2014 09:55 AM
amiskell
B7 Models
May 15, 2013 06:10 PM
tculber
B7 Models
Jul 11, 2011 11:15 PM
GodlessWickedCreep
Feb 4, 2011 07:15 PM
rocket455
Jul 24, 2009 09:39 AM
