random cylinder misfire , audi a6 2.7 T
Old Dec 9, 2008 | 03:15 PM
bandaru37's Avatar
Default random cylinder misfire , audi a6 2.7 T
Random Cylinder Misfire, OBD Code : P0300, The car seems to be starting fine, running as before and I dont see anything wrong with it. Is it because of a cold start? bad fuel? how can I reset it to see if it comes again without going to a mechanic?
Old Dec 9, 2008 | 08:15 PM
auditech79's Avatar
You need to check data block 32 using the VAG COM www.ross-tech.com and see what the fuel trim is. If its a + number then there is a vacuum leak that needs to be fixed. If not, its common for the coilpacks to cause random multiple misfires. I had to replace all 6 in my 2.7T S4 to fix my misfire problem.
Sheasta
Apr 23, 2013 10:04 PM
Maxmillion
Apr 8, 2011 12:26 AM
bandaru37
Dec 10, 2008 10:39 AM
twinblowersonice
Dec 12, 2005 04:07 AM
