RE:Driver side window
Hi Guys, i was driving around today, tried to put the driver side window up, went up half way and stoped,then all of sudden went down by itself with out touching it. by the time i got home tried it again and the window went up fine. this is the third time its doing this. any one had same problem, please let me know. Thanks . Ed. 2003 A6 3.0 fwd.
This appears to be a common problem. do a search for "window regulator clip" that is usually the culprit. I believe there is a pretty decent youtube video that walks you through the process of fixing it. really easy. cheap part.
I agree. I have changed the clips on my 98 A6, causing the same issue. The plastic clips break. It does take some time to open up the door and remove the window. I would have a friend help you when you swap out the clips.
Is window regulator clip different from window regulator? I couldn't find anything for window regulator clip. Here's what i found
Window Regulator - Auto Parts Warehouse
I have same problem on front passenger window, it goes up half way thru and seems it goes out of alignment so it goes back down. I have to push the window up while holding the button.
They look like this, but the ones from the dealer that are newer are red.
AUDI A6 WINDOW REGULATOR CLIPS FRONT RIGHT | eBay
I bought my clips from a dealer, but had to go to 2 to buy just the clips. One dealer would not sell me the clips only the regulator. Another dealer sold me just the clips.
The clip is part of the regulator, it is what connects the window to the regulator.
