Driver's side window binding
Hello,
I have an A6 Avant...the drivers side window needs to be realigned in its track...the motor is strong, but the glass shifts causing it to bind up.
does anyone have a step-by-step for this process? I can't even seem to locate the screws to remove the door panel!
Any help is appreciated.
Thanks.
Thanks.
This is well known issue with Audi windows. The window guides get worn out and the window binds on the way up, I don't think Audi sells the quides separately, only the whole regulator.
Check on AudiWorld, there are lots of write-ups about this issue, use search feature.
